mscott
Hi all,
Hope someone has seen this problem. I am trying to use a vbs logon script in the default domain policy per the user manual. I have copied both the lsclient.exe and startup.vbs file to the netlogon directory. When the script executes an error is returned indicating "The system cannot find the file specified". The lsclient.exe file is in the same directory as the startup.vbs script.
Any help would be greatly appreciated.
6 REPLIES 6
farmonline
may be should be "\\server\share\lsclient.exe lsserver"
for my longin script is \\server\share\lsclient.exe 192.168.xx.xx
Could you post the script and screenshots please
miki
I think, that you can also one more reason - network is not available at the moment of vbscript execution...
You should be sure, that network card is initialized and working... there is an entry inside GPO, which says something like "please wait with script execution, until network is available"... I don't remember exact location...
Unfortunately this setting will make a logon process longer..
Regards
Michal
taeratrin
The only reasons it would come up with that are :
a) You mis-spelled something
b) Share isn't actually shared
c) Users don't have permissions to the share
Double-check those things.
taeratrin
Easier way to do it than vbs : batch file -
"\\server\share\lsclient.exe" lsserver
Just one line.
Please post your complete script and some screenshots of your folder.
