jlanders
I am running a vbs script for my login script. I have the the script running however I get a popup indicating LSClient is unsigned. Does anyone know of a way to run this silent so that the users do not see a popup dialog?
Here is the script code line:
Set WshNetwork = WScript.CreateObject("WScript.Network")
Set WshShell = WScript.CreateObject("WScript.Shell")
Set WshProcessEnvironment = WshShell.Environment("Process")
'''''''' LoginServer Var
LogonServer = WshProcessEnvironment("LogonServer")
WshShell.Run chr(34) & LogonServer & "\netlogon\lsclient.exe " & chr(34) & chr(34) & "10.0.0.17" & chr(34)
just a guess : Add your local active directory domain ("mydomain.local") to the list of trusted sites in internet explorer.
jlanders
This occurs on both vista and XP.
is this on vista or xp?
jlanders
I tried that line. I still get a dialog box indicating "The publisher could not be varified. Are you sure you want to run this software?"
'*** lansweeper
if isworkstation then
WshShell.run logonserver &"\netlogon\lsclient.exe server",0
'",0" = windows is hidden
end if
