Chris
I have configured Lansweeper to work on Windows XP SP2,IE6, with SQL Server express 2005, apart from the fact that when starting the web console view, I get this error:
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.WebComputers'.
I'm no SQL expert and have no idea what it could be. Anyone?
It's in the web.config
Chris
Thanks.
Is this configures in the web.config? If not where is this set please?
You have pointed to the sql server and the server seems to be running, but have you connected to the correct database?
