zwzb
We have a problem with one Client. When we run lsclient.exe (with gpo or manually), the client cannot print!
What can that be? After a restart without running lsclient.exe it works!
Kind Regards,
Patrick
I'm sorry but I have no idea what might causing the problem and so far you are the only one experiencing this issue.
zwzb
No, lsclient.exe starts and says connecting... succes
It is only by one Computer the Problem, but we have tested everything, new windows installation, other location (other network connection), but all time the same.
First we thougt there is an issue in the vbs-script, but then i find out, when i delete the lsclient line, the printer works...
And yet, it works, but when i start lsclient manually it stops working...
There is only a bulb at the clock, that says "Dokument 1 cannot be printed..."
When i reboot the computer, the printer works fine, till i start lsclient once...
Maybe there´s a problem with the spooler an lsclient ??
Does lsclient give any error?
Do you get any error when printing?
Lsclient sends a message to the server and then stops working.
