I re-ran the service installer to get the default lansweeperservice.exe.config file back.
Changed that password to match what I have the lssqluser32 password set as.
Now I get this in the errorlog.txt file:
12/2/2008 3:45:48 PM : Cannot connect to database, check your config file, service will be stopped
Login failed for user 'lssqluser32'.
I've even gone in and reset the password in SQL manager to make sure it was correct.
