Options
‎12-01-2008 07:46 PM
using the connection tester everything passes.
however running "lsclient servername" just showings "connecting..." and then disappears.
running a netstat -a i do not see port 9524 listed.
this was working last week. all i changed was I wanted to enable authentication on the web console so I followed the steps on one of the threads on this forum.
Console still works and shows info from the first test run of the inventory but nothing new...obviously since the client isn't connecting.
The lansweeper service is running on the server system and all that shows up in the errorlog file is:
12/1/2008 12:17:50 PM
GetKeyValuePair 00-------------------------------------------------------------------------
Any suggestions?
This is running on a vista 32 bit workstation (wanted to test everything out before actually using it), so I had to do some tweaking with IIS 7 to get it to work in the first place.
Any suggestions?
Labels:
11 REPLIES 11
Options
‎12-02-2008 05:09 PM
web.config
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm" />
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=127.0.0.1;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=sweetpassword" />
<add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer" />
<add key="MM_CONNECTION_SCHEMA_Lansweeper" value="" />
<add key="MM_CONNECTION_CATALOG_Lansweeper" value="" />
<add key="dateformat" value="dd/MM/yyyy" />
</appSettings>
<system.web>
<authentication mode="Windows"/>
<identity impersonate="true" />
<authorization>
<allow roles="domain\it" />
<deny users="*" />
</authorization>
<compilation debug="True" strict="false" explicit="true">
<assemblies>
<add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A" />
<add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />
</assemblies>
</compilation>
<httpHandlers>
<remove verb="*" path="*.asmx" />
<add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false" />
<add verb="*" path="*_AppService.axd" validate="false" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false" />
</httpHandlers>
<httpModules>
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
</httpModules>
</system.web>
<system.webServer>
<handlers>
<add name="ScriptResource.axd_GET,HEAD" path="ScriptResource.axd" verb="GET,HEAD" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv2.0" />
<add name="*_AppService.axd_*" path="*_AppService.axd" verb="*" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv2.0" />
<add name="*.asmx_*" path="*.asmx" verb="*" type="System.Web.Script.Services.ScriptHandlerFactory" preCondition="integratedMode,runtimeVersionv2.0" />
</handlers>
</system.webServer>
</configuration>
<configuration>
<appSettings>
</appSettings>
<system.web>
<authorization>
<deny users="*" />
</authorization>
<assemblies>
</assemblies>
</compilation>
<httpHandlers>
</httpHandlers>
<httpModules>
</httpModules>
</system.web>
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</configuration>
Options
‎12-02-2008 12:15 AM
Could you post your config files please.
GetKeyValuePair usually means that you made an error changing one of the config files (probably lansweeperservice.exe.config)
