Ok, there are 2 helper components:
lslocal.au3:
Opt("TrayIconHide", 1)
Global $MainSocket, $szIPADDRESS, $nPORT
Dim $szServerPC = @ComputerName
Dim $szIPADDRESS = TCPNameToIP($szServerPC)
Dim $ConnectedSocket = -1
Dim $nPORT = 5555
$MainSocket = TCPListen($szIPADDRESS, $nPORT)
If $MainSocket = -1 Then
	Exit
EndIf
While 1
	$ConnectedSocket = TCPAccept($MainSocket)
	If $ConnectedSocket >= 0 Then
		While 1
			$recv = TCPRecv($ConnectedSocket, 2048)
			If @error Then ExitLoop
			Select
				Case $recv = "yes"
					MakeConnection()
				Case $recv = "no" Or $recv = "timeout"
					Exit
			EndSelect
		WEnd
	EndIf
WEnd
Dim $msg, $recv
If $ConnectedSocket <> -1 Then TCPCloseSocket($ConnectedSocket)
Func OnAutoItStart()
	TCPStartup()
EndFunc   ;==>OnAutoItStart
Func OnAutoitExit()
	TCPShutdown()
EndFunc   ;==>OnAutoitExit
Func MakeConnection()
	Run(@ScriptDir & "\lsremote.exe " & $cmdline[1], @ScriptDir)
	Exit
EndFunc   ;==>MakeConnectionlsremoteh.au3:
TCPStartup()
Dim $szServerPC = $cmdline[1]
ConsoleWrite($szIPADDRESS)
Dim $nPORT = 5555
$ConnectedSocket = TCPConnect($szIPADDRESS, $nPORT)
If ProcessExists("explorer.exe") Then
	If Not IsDeclared("iMsgBoxAnswer") Then Local $iMsgBoxAnswer
	$iMsgBoxAnswer = MsgBox(262180, "Remote Control", "Would you like Service Desk to take control of your machine?", 30) ;Timeout of 30s defined
	Select
		Case $iMsgBoxAnswer = 6 ;Yes
			TCPSend($ConnectedSocket, "yes")
			Exit
		Case $iMsgBoxAnswer = 7 ;No
			TCPSend($ConnectedSocket, "no")
			Exit
		Case $iMsgBoxAnswer = -1 ;Timeout
			TCPSend($ConnectedSocket, "timeout")
			Exit
	EndSelect
Else
	Exit
EndIf
	TCPStartup()
Func OnAutoItExit()
	TCPShutdown()
EndFunc   ;==>OnAutoItExitThe action should be:
cmd /c \\server\share$\Lansweeper\psexec.exe \\{computer} -i -s -c -f \\server\share$\Lansweeper\lsremoteh.exe %computername%| \\server\share$\Lansweeper\lslocal.exe {computer}lsremote.exe should be on the same share as lsremoteh.exe and lslocal.exe
