first question > I did
second one > I did now (finding 2 entries I changed)
now state aspx give the result
System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Could you give me one idea what you expect. Because all other things are running perfect. For example, I changed the description field of 20 Servers, run lsclient and all informations appear in the lansweeper webcionsole
