lemaitrem
Dear,
i have received your trial key and it work fine,
since that,
i updated from 3.5.0 to 3.5.1 and finaly to your beta 3.5.2
i found a litle problem when i use "user detail pane"
on the top of the windows,
i receive this error messages
System.Data.SqlClient.SqlException: EXECUTE permission denied on object 'Web30searchuserlogon', database 'lansweeperdb', owner 'dbo'.
could you help me or is it a beta error
thank you for your help
Marc
lemaitrem
thank's support
i'll find that table and only change the execute permission for that table to the lansweeper user and it works fine
have a good week end
lemaitrem
how can i correct this?
i rerun the sql request it gave me some duplicate fileds and the rest is complete and ok
other error,
the key you gave me was valid until 29/072009
but after the upgrade, it was reduce to 15/07/2009
First try to delete the Web30searchuserlogon from the database and then rerun the script
Your end date is 15/7.
Before the beta it showed enddate + 14 days.
Now it shows the correct date (15/7) and when you reach this date it will show another 25 extra days.
This part is from 3.5.1
Most likely you upgraded the database with a different user and the user running the sql/webconsole (lansweeperuser) doesn't have the correct permissions on the newly created objects (like web30searchuserlogon)
