Gene_Galaxo
I have added OU-Filter in the configuration. Scann not running. No Entry in the Logfile! If I remove the OU-Filter the Scann works fine. Version 4.0.0.2
7 REPLIES 7
The fix is implemented in the latest beta (2 March)
Gene_Galaxo
You have a mail
Could you post any screenshots.
I hope you made a mistake entering the data or I'll start to cry 😉
Gene_Galaxo
I have restart the Service and I have wait 30 min. before I started to cry 🙂
Did you restart the service after the filter apply or was active scanning already running and did you apply the filtering afterwards?
Gene_Galaxo
Yes. FQDN und Netbiosname add. I have used the same Config from my running version3
Did you also fill in the domain details?
If you use ou filtering for active scanning you need to fill in both.
