danielm
I just downloaded the primium tools since I saw this
Lsremote 4.1.0.15
Upgraded to the latest vnc version which fixes some known problems on windows 7 machines.
i was one before that.
I assume that means the LSREMOTE was updated?
either way it looks the same .
it also only has 2 files in the ZIP. lsremote and the remote uninstall
is this ok?
danielm
Ah, the Premium tools you mean. Ok I see it now in the ZIP.
thank you for the quick response.
can you try downloading the zip file again please, the new version is included now.
danielm
ok. then were does it go. It looked like the OLD version of lsremote was still in the actions directory...
in my case C:\Program Files (x86)\Lansweeper\Actions
Either way, it looks like it was not copied in.
Can it be downloaded or extracted from the install?
the new lsremote.exe is included in the installer which can be downloaded from http://www.lansweeper.com/download.aspx
