brittina72
Hello All,
First I'd like to say Lansweeper has been an amazing set of tools.
I move around from computer to comptuer a lot and use lansweeper and its tools on those random computers. I have to keep finding and putting in the lansweeper key each time I sit down at a new computer to register the tools.
Is there any way to register the tools so no matter what computer I'm at I can use them?
I have AD Authentication enabled on the site, so access is very limited.
Thanks,
-Andrew Brittin
brittina72
That worked. Thanks!
You can create a share with all the tools accessible to the people that need them, then place a file "license.txt" with your license key in the same folder
