kativo
Bye all, i'm italian and i have a problem with Lansweeper.
I don't speak very well english , but i want ask your to help me.
The problem is , when i go to http://MYserver i receive this message "Internet Explorer cannot display the webpage" and
in the event viewer i have this error :
1) aspnet_wp.exe (PID: 1052) stopped unexpectedly.
2) Failed to initialize the AppDomain:/LM/W3SVC/1699190916/Root
Exception: System.Configuration.ConfigurationErrorsException
Message: Exception of type 'System.Configuration.ConfigurationErrorsException' was thrown.
StackTrace: at System.Web.Configuration.ErrorRuntimeConfig.ErrorConfigRecord.System.Configuration.Internal.IInternalConfigRecord.GetLkgSection(String configKey)
at System.Web.Configuration.RuntimeConfigLKG.GetSectionObject(String sectionName)
at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index)
at System.Web.Configuration.RuntimeConfig.get_HostingEnvironment()
at System.Web.Hosting.HostingEnvironment.StartMonitoringForIdleTimeout()
at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters)
at System.Web.Hosting.ApplicationManager.CreateAppDomainWithHostingEnvironment(String appId, IApplicationHost appHost, HostingEnvironmentParameters hostingParameters)
at System.Web.Hosting.ApplicationManager.CreateAppDomainWithHostingEnvironmentAndReportErrors(String appId, IApplicationHost appHost, HostingEnvironmentParameters hostingParameters)
The IIS is configured correctly and the test of client connection is ok !
Lansweeper is intalled on Windows 2k3 Server .
We have an idea to resolve these error ?
Grazie / thanks
8 REPLIES 8
kativo
i have resolve the problem formatting machine and installing lansweeper 3.1
thanks , and i offer you a virtual beer for help
One more and I'm virtually drunk :d/
I did a search on google and found some suggestions
- make sure that everyone has full control on the website folder
- makes sure that the network service has full control on the temporary asp.net folders.
kativo
i check the permission and are ok .
Tomorrow at work i can do another installation\configuration of lansweeper to another computer
If you have new test to do i read tomorrow.
Did you run the "aspnet_regiis.exe -i" ?
kativo
yes, i run it and the new ASP .NET v2 web extension is allow in IIS
kativo
Lansweeper wrote:
Maybe this post will help you (aspnet_regiis.exe)
http://forum.lansweeper.com/yaf_postst197_Viewing-the-page-through-any-browser-is-messed-up.aspx
thanks for help, i have uninstall all version of asp.net and install only version 2.0 , but i have the same problem .
if reinstall all IIS 6.0 , i can maybe resolve the problem ?
