Here are all the error messages I am getting when doing install on different domain.
Creating Lansweeper Database
Error: Msg 1802, Level 16, State 4, Server PTEJCWVRPTSRV01, Line 2CREATE DATABASE failed. Some file names listed could not be created.Check related errors.Msg 5170, Level 16, State 1, Server PTEJCWVRPTSRV01, Line 2Cannot create file 'c:FilesSQLServer.1.mdf' because it already exists.Change the file path or the file name, and retry the operation.
Build Database Objects
Error: [DBMSLPCN]General network error. Check your network documentation.[DBMSLPCN]ConnectionRead (WrapperRead()).
Populate Database
Add application name and role
Error: Msg 15010, Level 16, State 1, Server PTEJCWVRPTSRV01, Line 1The database 'Lansweeper32' does not exist. Supply a valid databasename. To see available databases, use sys.databases.
Lansweeper service install
Not sure where to start looking to investigate this since there is nothing in event logs. Can you please help ?
