Takers
I have installed the Lansweeper following the instructions and the web console appears to work correctly and have managed to install a client no problems.
However, I cannot access the GUIConsole - it comes up with a Network Handshake error - [DBNETLIB][ConnectionOpen (PreLoginHandshake()).General network error. Check your network documentation.
I have looked at the error log and there is nothing stated there - any ideas?
MarkB
Take a look at your lansweeperservice.exe.config file, this contains the needed information
Should be something like this
Server : 127.0.0.1\sqlexpress
user : lssqluser32
pwd : mysecretpassword*-
Takers
Yes - I can get the console login box however I am unsure as to the information I need to put in.
The server should be the Server\SQL Instance I believe? i.e. \\127.0.0.1\TEST
The database name should be lansweeper32? This is default, and I have not changed this.
Username Password - I am assuming these are the sa credentials for the SQL instance? I put these in and get the error message I stated - very confused!
Takers
When you start the GUIconsole you need to fill in your database, username, password.
Are you able to see this screen?
Did you fill in the correct information?
