andreag
I've some problems to get Report Builder function properly.
This is the scenario:
- Report Builder launched from a client pc with integrated credentials (already added the relative security group as sql express login with dbo permissions)
- created a really simple new report called "prova2", without any kind of filter and/or conditions
When I start GUI Console (directly from server) I can see new report and add it to Digital Dashboard.
BUT when I refresh digital dashboard page came out this error:
System.Data.SqlClient.SqlException: Invalid object name 'web30repprova2'.
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
Is there anything missing in my report creation procedure?
Is there any documentation about creating new reports?
Thanks for your help.
andreag
it does a "select * from viewname" which chooses dbo.viewname by default.
Ok, but when a user create a view using Report Builder with integrated auth, the application create the view using user's schema instead of dbo default schema.
Anyway I found the solution: to change user's default schema on 'dbo'.
Obviously any exsistent custom view [domain\user].[view] needs to be recreated in order to be view from Report Builder.
Lansweeper reports shows the views from owner dbo by design.
andreag
No one can explain me if it's a bug or a design-related issue?
andreag
More information: probably is a sql 2005 schema naming related issue.
I've noticed that, usign integrated auth, the view is created with schema 'DOMAIN\User.web30repprova2', instead of 'dbo.web30repprova2'.
UPDATE: Yes, I confirm that is schema naming-related issue.
When I create a report locally on the lansweeper server (using his default sql user) I've no problems.
