Options
‎03-25-2008 11:00 PM
This is a new install when I goto the web page 'digital dashboard' shows me 'WMI access denied', but when I go to any other panel I get errors:
This error comes up on the service when I run the client:
System.Data.SqlClient.SqlException: Invalid object name 'dbo.Tsysreportsoftware'.
System.Data.SqlClient.SqlException: Invalid object name 'dbo.Tsysreporthardware'.
3/25/2008 2:37:32 PM : ACAD4102
System.Data.SqlClient.SqlException: Invalid column name 'computername'.
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable)
at Lansweeper30.sweeperthread.OkName(clsComputer MyComputer, clsThreadinfo Threadinfo, SqlConnection& sqlcon)
Labels:
12 REPLIES 12
Options
‎03-26-2008 11:57 AM
Right click database/properties/collation name
Options
‎03-25-2008 11:22 PM
I just ran the batch file that came in the package. I didn't do anything else.
We have a SQL server that has many databases, but I'm no expert with SQL. How would I check that?
Options
‎03-25-2008 11:06 PM
Just a quick guess : You have configured your database with a case sensitive collation instead of a case inSenSiTivE
