‎03-25-2008 11:00 PM
System.Data.SqlClient.SqlException: Invalid object name 'dbo.Tsysreportsoftware'.
System.Data.SqlClient.SqlException: Invalid object name 'dbo.Tsysreporthardware'.
This error comes up on the service when I run the client:
3/25/2008 2:37:32 PM : ACAD4102
System.Data.SqlClient.SqlException: Invalid column name 'computername'.
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable)
at Lansweeper30.sweeperthread.OkName(clsComputer MyComputer, clsThreadinfo Threadinfo, SqlConnection& sqlcon)
‎03-27-2008 05:52 PM
‎03-27-2008 05:29 PM
‎03-27-2008 05:22 PM
System.Data.SqlClient.SqlException: Invalid object name 'dbo.web30licensecompliance'.
System.Data.SqlClient.SqlException: Invalid object name 'dbo.web30oslicensecompliance'.
‎03-27-2008 05:14 PM
‎03-27-2008 05:04 PM
Locate the file "createdatabase.sql" and change it to:
USE [master]
IF EXISTS (SELECT name FROM master.dbo.sysdatabases WHERE name = N'Lansweeper')
DROP DATABASE [Lansweeper]
GO
CREATE DATABASE [Lansweeper] collate Latin1_General_CI_AI
GO
‎03-27-2008 04:59 PM
Thanks!
‎03-27-2008 04:55 PM
(which is different from yours)
‎03-27-2008 10:12 AM
CI = case insensitive
‎03-26-2008 10:39 PM
