progdlp
I can remote desktop to the lansweeper server and use the web console there. I can also type the server name:9524 and see that the service is running and the systems that have been scanned. However I am not able to go to the web console directly from my pc. I have typed the server name as the url and I get a login box but no matter what login I use I cannot get in. I installed iis 6.0 admin pack for xp and that is what got the login box but unable to get past that. Is there a port to add to the server name like the 9524 to see if it is active. Thank you.
This is the PREMIUM VERSION.
progdlp
Is this settings for the server or the system I am trying to use to connect.
The proxy is for the webbrowser that you use to connect to the server.
Please send a screenshot of your webbrowser including the login prompt.
And also a screenshot of the tab where you enabled anonymous access.
It might also be the login prompt from a proxy server, disable the proxy or add the server to the list of exceptions.
progdlp
I do have anonymous access configured. I did this in the inetmgr configuration. What specifically do you need to know about the configuration. What tab do you want a screen shot of? Please be specific.
Could you post a screenshot of your IIS setup please.
If you enable anonymous access (what the installer should do for you) you should be able to access the host with all users.
