neosys
I am tring to build a new report to see the screen manufacturer for each PC - to link with asset tags...
On the web interface I sometimes only see one desktop screen whereas there should be 2 connected.
Any Idea why they would not show up ?
thanks,
Neosys
Groupe Rodeus
Do a select only on tbldesktopmonitor, then you can see how many entries there are for each computer.
neosys
I believe my SQL query is not correct but I am new to this.
Groupe Rodeus
So it's a scanning problem?
neosys
In the report I cannot as of now report what I need.
using the web interface I can see 2 screens attached to a PC but for another one I can only see one.
This is what I figured I needed in the report builder:
SELECT
dbo.tblComputers.Computername AS Computer,
dbo.tblOperatingsystem.Description,
dbo.tblComputersystem.Manufacturer,
dbo.tblComputersystem.Model,
tblDesktopMonitor.MonitorManufacturer,
tblDesktopMonitor.DeviceID,
tblDesktopMonitor.ScreenWidth,
tblDesktopMonitor.ScreenHeight,
tblDesktopMonitor.Computername
FROM
dbo.tblComputers
INNER JOIN dbo.tblComputersystem ON (dbo.tblComputers.Computername = dbo.tblComputersystem.Computername)
INNER JOIN dbo.tblOperatingsystem ON (dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername)
INNER JOIN tblDesktopMonitor ON (dbo.tblComputers.Computername = tblDesktopMonitor.MonitorManufacturer)
But I am missing parts in order to get results out of it.
Groupe Rodeus
Is the problem that your report is showing incorrect information or that lansweeper is not scanning all data?
Please post any screenshots,... that you can provide.
