Options
‎06-25-2009 12:32 AM
Sometimes when i am building a report using the GUI rather than enter the script myself. I'll be going through and checking my results as i add each condition. Occasionaly i'll enter in a condition and it will make my results come up blank....but the odd thing is that if i save it..i can go out and check it in the report output tab and it will have the correct results.
This threw me off for the longest time, but then i realized on accident that i was actualy doing it right...it just wasn't show the result in the report editor.
Am i doing something wrong or is it just a bugg/ glitch.
I've managed to work around it by saving the report and checking the reports in the output tab rather than in the editor's result tab
thank you
Taylor J
thank you
Taylor J
Labels:
Options
‎07-14-2009 10:05 AM
The report builder uses a third party component (which has the bugs).
After months of waiting for fixes we decided to switch to another component, so you should expect a new beta in a couple of weeks.
Options
‎06-25-2009 01:27 AM
I have had this too but it never bothered me.
I just switch tabs, from Builder to SQL for example, then hit the results button. I think then you make a change the builder needs you to do something else before it sees it.
Options
‎06-25-2009 01:32 AM
That usually works, but i've had at least two instances where the only thing that would make it work was to do as i describe earlier. Even exiting Report Builder Completely and going back in, edit the report in question, hit results, and it i will still be blank. Even though the Report output had data in it form the exact same report
