ahahum
I am getting the reverse lookup failed error for many of our laptops. I have scavenging setup on the DNS zones and I have verified that it is working and correctly removing old records.
At our main office we have a separate VLAN for wireless so I think the problem is coming from when the reverse lookup returns an address from the oposite VLAN it is currently active on.
All of our remote sites only have 1 VLAN so a particular computer will usually have 2 records in DNS from the same subnet...one for wired and one for wirelss. Is there any way to get around these errors on machines that have 2 different legit DNS records?
I would assume a possible solution would resolve both scenarios I am experiencing.
Thanks in advance!
Adam
Version 3.5 scans on FQDN by default to fix this issue, you can download the beta from the forum
