DMermod
I've just recently started using the software and have a question.
When setting up the scanning credentials I would like to have the scanning credentials for domains/workgroups with the same name work.
For example. Domain = TestSite and Workgroup = TestSite.
When attempting to add credentials for the workgroup (after already inserting the domain). I get the following error:
Violation of PRIMARY KEY constraint 'PK_tsysDomainPasswo__xxxxxxxx.' Cannot insert duplicate key in object 'dbo.tsysDomainPasswords'
I'm hoping there is a workaround due to the massive amount of machines on both sides already and putting the machines on a new workgroup is not a solution on my side.
Thanks in advanced for the advice and suggestions.
- DRM
It is not currently possible to scan a domain and workgroup with a shared name.
This functionality will be available in Lansweeper version 5. We do not yet have a release date for this version.
