waverlyr
When I run the lansweeper.sql I get the following error:
Warning: The table 'tblADusers' has been created but its maximum row size (22084) exceeds the maximum number of bytes per row (8060). INSERT or UPDATE of a row in this table will fail if the resulting row length exceeds 8060 bytes.
Is there a work-around or fix for this?
Don't worry, just ignore 🙂 (it's a warning)
The update will never be bigger as 8060 bytes
