Options
‎05-04-2010 12:37 PM
Hi there,
We have this annoying issue. We've been using Active Scan for quite a while, and recently upgradet to V.4.0.0.x (at 4.0.0.24 now).
Since upgrading, Active scan does not work, neither does IP-range scanning produce any resulte.
Running LSCLIENT against the server works fine, and updates the database.
Any ideas?
Errorlog.txt show this... (and I'm puzzled by the Freeware version line, as we are registered user of the Enterprise edition)
04-05-2010 10:26:47: Dynamic SQL generation for the UpdateCommand is not supported against a SelectCommand that does not return any key column information.
at System.Data.Common.DbDataAdapter.UpdatingRowStatusErrors(RowUpdatingEventArgs rowUpdatedEvent, DataRow dataRow)
at System.Data.Common.DbDataAdapter.Update(DataRow[] dataRows, DataTableMapping tableMapping)
at System.Data.Common.DbDataAdapter.UpdateFromDataTable(DataTable dataTable, DataTableMapping tableMapping)
at System.Data.Common.DbDataAdapter.Update(DataTable dataTable)
at LansweeperService.MdlLicenceCode.CheckLicense(SqlConnection& sqlcon)
04-05-2010 10:26:47: Starting up service 4.0.0.24, port 9524, 10 computer threads, 10 IP threads
04-05-2010 10:26:47: Freeware version
Any ideas?
Labels:
Options
‎05-04-2010 01:03 PM
Done...
Options
‎05-04-2010 12:44 PM
Could you mail to lansweeper@hemoco.com your errorlog.txt file, and the output of "select * from tsysconfig" please.
Is this installation an upgrade or a new install?
