jcasilva
Solution for errors of RPC and “access permission” exactly after to incapacitate firewall of the XP and exactly after update in Win2000.
I found a solution for when the machines, exactly with all the updates and taking off firewall, give to the errors of The RPC server is unavailable. (Exception from HRESULT: 0x800706BA or ACCESS DENIED.
SYMPTOM: The machine alone effects the software survey and several other information are not collected.
CAUSE: This problem if gives, or for the service of DCOM not to be qualified (initiated) and/or for error of permission.
SOLUTION: In 2000:1. Using DCOMCNFG.EXE, it selects the guide Properties standard. 2. To define the authentication level standard for “None”. 3. To define the representation level standard for “Anonymous”. Moreover, in default security, to add to the group of domain admins of the domain with complete access in all the configurations of users and groups of this border. In the XP: In the XP it is a little different, to effect procedure exactly however following the step below: http://consumer.installshield.com/kb.asp?id=q108324
0 REPLIES 0
