Options
‎03-08-2011 11:52 AM
Since I upgraded our Lansweeper to 4.1 I have gotten these errors from time to time and had to reboot the server.
Any suggestions on how to fix this?
System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Labels:
Options
‎03-08-2011 01:58 PM
Thanks!
I've run the script and there where no errors. Lets hope stays that way! 🙂
Options
‎03-08-2011 01:36 PM
Please try the following:
1) stop the service
2) run database script "execute psysrebuildallindexes"
3) start the service
1) stop the service
