foghat
I am intersested in supercrypt 2.0, but since there is no demo (that I can see), I am doing some preliminary testing with a version of 1.0 I found.
Thing is, I must be entering the parameters wrong, as I can't get things to work.
Initially, I am simply trying to call a bat file (aplink.bat) with contents of:
echo hello
pause
Supercrypt.exe and aplink.bat are sitting in c:\test\supercrypt
I have entered the following in supercrypter:
Command: "C:\test\supercrypt\aplink.bat"
Executable: aplink.bat
Runpath: C:\test\supercrypt
I then create the lsc file (bat.lsc) and have created a shortcut to supercrypt.exe. within the shortcut properties I have:
target: C:\test\supercrypt\supercrypt.exe "c:\test\supercrypt\bat.lsc"
start in: C:\test\supercrypt
This does not seem to work. I have also tried various other 'entries' in the command, executable, runpath parameters, but to no avail.
Any help would be great.
I'm sorry but supercrypt 1 is no longer supported.
