Options
‎02-23-2011 12:27 AM
I was running latest, last version. Did not try the beta of 4.1.0.14. Database schema as 10. As I have a customized setup (non-default database name), I've been able to just run the sql scripts manually. Problem this time. I get the errors below running upgradescript11.sql:
(0 row(s) affected)
Msg 1779, Level 16, State 0, Line 1
Table 'tsysreports' already has a primary key defined on it.
Msg 1750, Level 16, State 0, Line 1
Could not create constraint. See previous errors.
(0 row(s) affected)
Table 'tsysdonotscan' already has a primary key defined on it.
(0 row(s) affected)
Table 'tsysserials' already has a primary key defined on it.
(1 row(s) affected)
The constraints are not getting created.
Thanks,
Joe
(0 row(s) affected)
(0 row(s) affected)
(0 row(s) affected)
(1 row(s) affected)
Thanks,
Joe
Labels:
Options
‎02-23-2011 03:54 PM
Thank you.
Updatescript12 ran fine. All is working great.
Options
‎02-23-2011 12:45 AM
I'm thinking that with the PKs already there, that these 3 errors are because what was being updated/added by upgradescript11 already exists. (The altered view and schema version update ran fine.)
Options
‎02-23-2011 09:37 AM
This is normal behaviour and can be ignored.
