Sachin
Hi
I am using Lansweeper premium tool .I have put lansweeper tools in a share folder on the server.But when i am trying to use the controls using this tools ,nothing is happening in the target systems.
I tried even shutdown,reboot option by clicking the corresponding web control panel, but it is not affecting on the target PC.
But suppose if i am trying to use "shutdown -r -m \\Target-PC" from the command prompt from my PC , it is affecting on the target PC. Can you please tell me the "Action Screen " options will work by clicking the corresponding links in it or not.If yes ,where i am wrong ?
Sachin Raj T N
MTD
Hey,
due to an Firefox update to Version 3.6 the cosum actions do not work anymore ? Does anybody has the same problem or an solution for me ?
Daniel
MTD wrote:
Hey,
Daniel
Problem confirmed, we are working on a fix.
To which location is the action pointing?
Is screengrab.exe located in this folder?
Sachin
Hi
Thanks for your support.I am through with the common exes like ping,traceroute, eventviwer etc.But i am not able to get the premium tools.Please find the screen shot
See these 2 links:
http://www.lansweeper.com/kb/customactions.aspx
http://www.lansweeper.com/kb/firefoxplugin.aspx
Which browser do you use?
Do you get an error when clicking on the link?
