asldesktop
I would like to administer Lansweeper from a workstation using lsmanage.
I am the desktop support for our company, and I am the main user of LS. Our network admin can use lsmanage.exe on the server it is installed on but I do not have access to this.
Is there a way I can use lsmanage on my desktop workstation? I am currently getting the following error when trying to connect:
"Provider Cannot Be Found. It May Not be Properley Installed"
Any help is appreciated.
Re-installing MDAC on this workstation should do the trick
http://msdn.microsoft.com/en-us/data/aa937729.aspx
asldesktop
Windows XP SP3.
Which OS are you running?
