Steve
Line: 1742
Char: 12
Error: Sys.ArgumentTypeException: Object of type 'Object' cannot be
converted to type "array'
Parameter name: array
Code: 0
URL: Http://myserver/lansweeper31/default.aspx
also getting the following error on action screen items.
Line: 270
Char: 3
Error: Automation server can't create object
Code: 0
URL: http://myserver/lansweeper31/default.aspx?
item=compdetail&comp=mycomputer
Which version of internet explorer are you using?
Could you post a screenshot of the complete page and error please.
If possible, could you post the code on line 1742
Steve
I posted all the information I was able to find. If you can tell me where else I can find more info I will post it. Each web page I pull up says "Done, but with errors on page". The Internet Explorer security setting I was able to resolve. Any other help would be appreciated.
Error: [Exception... "'Sys.ArgumentTypeException: Sys.ArgumentTypeException: Object of type 'Object' cannot be converted to type 'Array'.
Parameter name: array' when calling method: [nsIDOMEventListener::handleEvent]" nsresult: "0x8057001c (NS_ERROR_XPC_JS_THREW_JS_OBJECT)" location: "<unknown>" data: no]
Could you post the complete detailed output of the first error please.
You can lookup the second error on the forum (internet explorer security settings)
