rasmusan
We have a lot of Entra ID Joined devices.
I have added an account to the local administrator group of the device, and are trying to use that as a credential on the IP range containing the devices, however I continously get credentials error on the assets when trying to scan... trying using differnet username formats like
UPN (username@domain.fqdn)
AzureAD\<UPN>
AzureAD\<USERNAME>
DOMAIN\<USERNAME> etc.
Please advise on how to correctly conduct scanning of Entra ID Joined devices
DavidPK
If your Azure Active Directory is synced with a local Active Directory, Lansweeper can continue to scan your machines via AD scanning targets. If your Azure Active Directory is not synced with a local Active Directory, you can scan your machines via an IP Range Scanning Target if those machines have a local administrator account which can be used to scan them properly. Without a local administrator account, this will not be possible, unfortunately.
Alternatively, you could also make use of our LsAgent scanning agent for those machines to scan them regularly.
The machines af "entra joined" which means they do not exist in local Active Directory... So the only option I have is to deploy a local user with local admins rights and scan this way?
/Rasmus
