edfelopi
I have around 1000 workstation. LS can access 800 of them. 200 cas wmi or other access problem.
Within the 800 audited computers, there are 2 that appears in the "All workstations without antivirus". In LS does not appear the antivirus software. I made a full scan, and now appear new things, but not the antivirus.
Actually both of them have ESET 4.2.67.10, but it does not appear in the LS software table
6 REPLIES 6
oksidant
I have installed Kaspersky Anti-Virus for Workstations v6.04. Also writes that the antivirus is not installed. Why?
If the software is discovered you need to add it in the configuration tool/anti virus software
Thanks for the advice. I have installed Kaspersky Anti-Virus Russian version. I added a title in Russian and everything was fine.
Thank you very much.
Can you please contact us by e-mail for this problem
Please provide a .reg export file from key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
Which version of Lansweeper are you using?
Is the workstation 32/64 bit?
edfelopi
Yet. ESET Nod 32 appears in the add and remove programas
Is the software visible in the add/remove programs on that computer?
