tdmac12
I'm needing to create a deployment package that will delete a folder and its contents named Win11Upgrade on C:.
I've only created packages to install software, but never to delete a file or folder. Is there a package already out there that I can copy, or someone on here that can help me get started in the right direction?
Thanks!
Obi_1_Cinobi
Hello there!
For deleting files, you have several types of deployment steps that you could use:
  • Command: allows you to run Command Prompt (CMD) commands on the target computer.
  • Script: allows you to run a VBS or other type of script on the target computer. Don't forget to store your scripts in your package share(s). The scripts referenced by the built-in deployment packages are stored in DefaultPackageShare$ on your Lansweeper server, in the Scripts subfolder.
For more information, you can refer to this KB article: https://community.lansweeper.com/t5/deploying-software-other-changes/create-a-deployment-package/ta-...
MrRogers
Create a new deployment package and add a Command step using command: RMDIR "C:\Win11Upgrade" /S /Q
This can be used on all deployment packages if the installation file/folders have been copied locally and you want to clean up at the end of the deployment.
This requires elevated rights so using a package by itself use System account.
If this command is added to an existing deployment package, the credentials used for deployment should work for the deletion.
Obi_1_Cinobi
Hello there!
Deployment Packages
Share topics/ issues related to deployment packages. Please use/rely on content with caution as it is publicly generated.
