We're excited to have you here!
Flow builder is the new feature to boost your team’s efficiency through custom and automated workflows.
To get the most out of Flow builder we highly recommend following these steps:
  1. Watch the tutorial: Start by reviewing this tutorial to understand the basics of Flow Builder: Build your first workflow. It will help you get up to speed quickly in less than 30 minutes.
  2. Build your own workflows: Begin creating workflows tailored to your needs. Use the templates provided as examples, and be sure to reference the documentation for guidance as you build: What is Flow Builder?
  3. Provide your feedback: Click on the Give Feedback option in the Flow builder left-hand side menu to share your experience with us. If you have any questions, support is available in this community channel. We value your input and look forward to hearing from you!
Additionally, there are a few limitations you should be aware of while using Flow builder:
https://community.lansweeper.com/t5/flow-builder-program/flow-builder-preview-limitations/ba-p/80536
Thank you for being part of this journey. We're eager to see the workflows you create and hear your thoughts!
Moderator
27 79 16
