swright
I'm trying to create a query where one of the conditions is a field without a value.  Under the Operators for List of Assets, I see an operator of EXISTS, but not an option for when the field has no value.
path: "currentItem.assetCustom.fields.Server Type",
        operator: NOT EXISTS,
        value: ""
Or Value is NULL?
I have the option to check for NOT EXISTS in the Branch, but I don't want to loop through all assets every time the I run the flow.
Any ideas?
Vicente_SC
Moderator
Moderator
You can filter for fields that exist/not exist in the Filters section of the "List of Assets" action with an expression like this one:
    conjunction: AND,
    conditions: [
        path: "asset.general.serial_number",
        operator: EXISTS,
        value: "true"
However, take into account that we don't support all the fields in that filter section. The fields we support for that filtering option can be found here: https://community.lansweeper.com/t5/connectors/lansweeper-connector/ta-p/85179#toc-hId--13128466
If you want to filter by a field not in that list, the best option is to use a "Filter" action after the "List of Assets" step.
In the future, we plan to add more pre-filtering capabilities, so the workflows can bring only the needed data and be more efficient.
swright
Thanks for the quick response.
Vicente_SC
Moderator
Moderator
    conjunction: AND,
    conditions: [
        operator: EXISTS,
        value: "true"
Forum
