08-17-2022 07:01 PM - last edited 3 weeks ago by Mercedes_O
Can you change the info type on existing Asset Management fields?
We would like to have standard options for several of the predefined fields in asset management (e.g.: Location, Building, etc) and would like to offer a drop down versus text field.
I hate to create a custom field that duplicates a field already available.
09-08-2022 09:55 AM
Hi @CShoffner2021 ,
Thank you for your suggestion. I think it's very interesting.
This ability to add custom value libraries to standard fields that are now inputs, could you tell me more examples in which it would be useful to you?
We have an open survey on the management of custom fields. I would love for you to complete it and add your suggestion for improvement so that we manage your feedback properly and can work on it in future iterations: https://az5krgaymnz.typeform.com/to/yazGJZbA
Thanks in advance.
Kind regards,
Laura
09-07-2022 06:12 PM
Hello @CShoffner2021! You will not be able to change the standard Asset Management fields from a text box to a drop-down. The only way to achieve what you want would be through a custom field.
