rader
I'm building a report to display Hyper-V Generation, Memory, CPU count and Original Backup Method to recreate a new baseline Hyper-V starting print for restores. However I cannot find any reference to Hyper-V's Generation parameter in the database documentation.
Does anyone know how I can retrieve this value from Lansweeper?
rader
Thanks @Mister_Nobody
Interesting, but not what I was looking for. The link references the hosts impact on the VM's.
I was looking for a field that reported back what generation the Hyper-V VM was created under, Gen 1 or Gen 2. I have some VM's that were created under Gen1, even though they could have been a Gen 2 model. Legacy builds that were in place before newer versions were available and can't readily be changed or redone.
I use this info if I have to restore the VM's from bare metal backups. Easy to wipe out the VM and environment and rebuild the Hyper-V bits, then bare metal restore. Faster than fixing a pooched environment in my cases.
Best I've come up with is a custom field called Hyper-V Gen. and use that in my reports.
Mister_Nobody
Honored Sweeper
You can try to create table with Bios or UEFI Date and assign it with Hyper-V Generation and virtual HW version
Gen1 uses BIOS, Gen2 uses UEFI
Dates example
17/12/2019
18/05/2018
28/04/2016
26/11/2012
23/05/2012
Compare Hyper-V virtual Hardware
https://learn.microsoft.com/en-us/windows-server/virtualization/hyper-v/deploy/upgrade-virtual-machi...
