Hi Lansweeper Community!!
I am currently evaluating your product for use as a software licensing and usage tracking tool and would like to know how you collect the Installed Software Details.
Do you scan the entire laptop looking for applications and then registering?
Do you scan the Registries "Add Remove Programs" keys and report on those?
Both of the above?
Another method not mentioned? (If so, how??)
Are you able to monitor the usage of applications on computers.
Regards
Mike Kennedy
Senior Systems Support Specialist
