tlflorek
I like using TeraTerm and am trying to create a custom action to login to an asset. I am a new user and obviously doing something wrong or misunderstanding the actions capabilities. I tried to replicate the Putty action but it does not work. Any ideas?
{actionpath}ttermpro.exe{ipaddress}
CyberCitizen
Honored Sweeper
I would suggest looking here first off to make sure you are using the correct command lines. First thing I can see is there is no space between the file name and the ip address.
I would try this.
{actionpath}ttermpro.exe {ipaddress}
https://ttssh2.osdn.jp/manual/en/commandline/teraterm.html
I would try this.
That's it ! Thanks.
