08-13-2024 05:02 PM
We are receiving the error "Preliminary checks failed! Task Service Error. Access is denied. (0x80070005 (E_ACCESSDENIED))" when we attempt to deploy any packages. I have verified that the credentials we are using are correct. I also tried the connection tester and it all comes back with no errors.
Has anyone had a similar issue? (I did submit a ticket as well)
thanks!
Solved! Go to Solution.
08-13-2024 05:15 PM
looks like this is an issue related to 11.4.0.3 and they are working to deploy a fix.
3 weeks ago
Dear all,
We released 12.1 today, which contains a solution that solves the outstanding issue we had with deployments.
We regret the inconvenience this caused. You can find the new release on the page below:
Update your installation - Lansweeper
3 weeks ago
I am slowly getting sick of your product. How long will this nonsense that deployment does not work last. I have reinstalled LanSweeper from scratch on a clean server and still not working! Currently using the latest version and it doesn't work, it hasn't worked since version 11.2. What am I paying you for? For a half-baked product? Your competitor pdq works perfectly no problem. I'm asking for a quick solution, because this thing is already total nonsense
3 weeks ago
Hello Pealik,
We regret the inconvenience this causes, and we get that many customers rely on the deployment feature. We have been working on a fix which will be made available later this week. We are finalizing and testing the build now.
It will be made available on our update page with a beta label because we want to get confirmation from customers first for a few fixes that are in there.
Please keep an eye on the page below the coming days. The release will be 12.1. As said it will be listed as a beta release, but it is a full release, QA approved.
We hope that with this release, you will get your deployments running again.
3 weeks ago
Also, run the command directly from the machine, then it works flawlessly! So the error is in your product, please solve it quickly!
09-03-2024 10:49 AM - last edited on 09-03-2024 06:04 PM by Mfaiz
The deploy part still doesn't work and gives errors. I have upgraded to 11.4.1.2 and still the same. I also installed Lansweeper from scratch with 11.4.1.2 version and still the same. What is going on? When will it be fixed, this is not normal and I am already very upset.
09-03-2024 08:04 PM
Hello there!
Our tech support team should be able to assist you with this.
08-16-2024 02:17 PM
Dear,
If you are still facing issues with deployments, please contact Lansweeper Support. They should be able to help you out with this.
Apologies for the inconvenience this causes.
08-15-2024 04:01 PM
I actually spoke too soon. The vast majority of my deployments are working, but I'm still randomly getting Error: Wrong Credentials, so I would say that the issue is not 100% fixed.
08-15-2024 04:03 PM - edited 08-15-2024 04:18 PM
How were you able to get the update? When I try to access the site, I am getting a "Server Error in 'Application' " error.
Nevermind, I got the update
