We are running the LanSweeper in the IIS setup (not IISexpress), due to prerequisites from our ISO.
The IIS is successfully configured to use a custom certificate, however the LS Push Service at TCP/9524 always comes up with the selfsigned lansweeper certificate, which is currently identified as a possible vulnerability and needs to be resolved. I have double checked this with openssl s_client.
I have followed the relevant KB articles to setup a custom cert.
- The custom cert is in the local computer cert store, incl. the private key and it is exportable.
- I have altered the IISExpressSvc.exe.config, like following
 <add key="UseCustomSSLCertificate" value="1"/>
 <add key="CertificateThumbPrint" value="‎d843[foo]ca5c"/> (Thumbprint from custom certificate)
Upon start/restart of the LanSweeper service, I can see in the Logfile from the thumbprint that the LS Push Service still uses the selfsigned LS certificate:
2018-09-18 15:44:43,340 [4] INFO  Starting service
2018-09-18 15:44:51,512 [4] INFO  Started [bar] v7.0.30.66 by NT AUTHORITY\SYSTEM, port 9524, 10 Threads, 10 IP Threads, 1 Scanning Servers
2018-09-18 15:44:51,559 [4] INFO  Operating System: Microsoft Windows Server 2012 R2 Standard (OS language: English (United States), OS version: 6.3.9600), Service Pack version: 0
2018-09-18 15:44:51,575 [4] INFO  .NET Framework version: 4.7.3163.0
2018-09-18 15:44:51,575 [4] INFO  Database: SQL Server 2016 (version: 13.0.5081.1) Express Edition (64-bit): localhost\SQLEXPRESS, 550.51 MB used
2018-09-18 15:44:51,575 [4] INFO  License: Professional version, [foo], [bar] licensed assets
2018-09-18 15:44:51,637 [Listen] INFO  Using existing SSL certificate. ThumbPrint: CD3CA9AF10778698C61520C081DC889B8E559882How do I tell the service to use the custom certificate when I am not using IISExpress as webserver?
Best regards
Jörg
