aydinvaliyev15
Visitor Sweeper
few days ago i updated version to 12.3.2.3 and then scanning got slowed down and also database size before upgrading 2 gb left but now only 800 mb left. Assets are the same number almost . how this even sizing up like this . thanks in advance
Mister_Nobody
Honored Sweeper II
See DB Size
https://LS_server_name/Configuration/DatabaseOptions/
LS 12.3 has hidden firewall rules scanner.
Disable it via scan interval settings.
6 REPLIES 6
aydinvaliyev15
Visitor Sweeper
Disabling firewall features is the solution of slowing down . Just in case , i have just one problem about database sizing up . i am in touch with lansweeper support team .
Mister_Nobody
Honored Sweeper II
See DB Size
Thanks it works for me . It took approximately 2 minutes per machine and i have a lot of assets . i disabled this and scan got very quickly . i just got one problem .
Thanks .i am gonna try this way and share results with you
FrankSc
The main thing to see is which table is causing this exponential growth. This can be seen under Configuration\Database tables.
It seems you are in contact with our Support team. They should be able to identify and assist you furhter.
Yes i am in touch with your support team . I hope everything is gonna be okay. Thanks in advance
