My third blog covers Remote Desktop Services along with how you can report on the servers running it so you can monitor them a little better, you can find it in the Pro tips #3 blog post.
2 Comments
Guest
I get this error when trying to save the report:
The multi-part identifier "tblAssets.AssetName" could not be bound. The multi-part identifier "subquery4.AssetName" could not be bound. The multi-part identifier "subquery4.MetricName" could not be bound. The multi-part identifier "subquery5.AssetName" could not be bound. The multi-part identifier "subquery5.MetricName" could not be bound.
Make sure to remove everything in the report editor before you paste in the report you copied from the site. Also any accidental characters copied along with the report code can cause that issue.
