In this month's Pro Tip, I cover how you use ChatGPT as a digital assistant to create advanced reports. It's especially helpful if you're not that familiar with coding your own advanced reports. I also share some other tips on how to make reporting easier. Try it out for yourself, you can find all the info in the Pro Tips blog post.
1 Comment
AirConditioner
Is Cloud Reporting feature rolling-out ? I can not see is the new UI preview.
