This documentation is for the new preview UI. It’s still being refined and is subject to change. For documentation for the old UI, see Knowledge Base.
Article link copied to clipboard
Updated
Published
4 min read
Audit trail is a foundational security feature in Lansweeper Sites, designed to fill a key visibility gap in user activity monitoring. It enhances audit readiness by providing clear records of who did what and when, directly within your Lansweeper Site.
Lansweeper’s audit trails capture user actions across four key areas: configuration changes (e.g. discovery settings or site setup), inventory edits (e.g. manual asset updates), view exports or API access, and user logins. These events help ensure accountability and support internal or regulatory audits.
Audit trail data is stored securely for up to 12 months and includes user-identifiable actions, and can be exported for further analysis. Because the data may include personally identifiable information (PII), it's intended for compliance and internal audit use, not for routine support cases.
Export audit trail data
You can export audit data for reporting, review, or long‑term archival directly from within your Lansweeper Site.
To export a timeline of user and system activity in your Lansweeper Site:
  1. In your Lansweeper Site, go to Configuration > Audit trail.
  2. Select Export audit trail.
  3. In the popup, select the file type.
  4. Select Export.
Export audit trail data via the Data API
For automated workflows, integrations, or advanced analytics, audit trail data can also be retrieved using the Lansweeper Data API.
The Data API includes a dedicated AuditTrail data type, allowing you to filter records by date or event type, retrieve detailed user information, and manage large datasets through built‑in pagination.
For technical details and schema definitions, check out the Types specification.
Audit trail events
Currently, audit trails are grouped into four main categories: site access, accounts configuration, inventory configuration, and custom views.
All plans have access to site access, accounts configuration, and custom views. Inventory configuration is only available on Pro and higher plans. For more information on plans, check out the pricing page.
Site access
Tracks when users access your Lansweeper Site.
Endpoint
Description
siteAccess
Tracks when a user accesses the site
Accounts configuration
Tracks changes to user roles, groups, scopes, and related permissions.
Endpoint
Description
addRole
Creates a new user role
updateRole
Edits and updates an existing user role
deleteRole
Deletes a single role
deleteRoles
Deletes multiple roles in bulk
createScope
Creates a new permission scope
updateScope
Edits and updates an existing scope
deleteScope
Deletes a single scope
deleteScopes
Deletes multiple scopes in bulk
scopesBulkUpdate
Edits and updates multiple scopes in bulk
updateProfile
Edits and updates a user profile
deleteProfile
Deletes a single user profile
deleteProfiles
Deletes multiple profiles in bulk
leaveSite
Tracks when a Lansweeper user leaves the site
toggleBlockedAccount
Blocks or unblocks an account’s access to the site
createGroup
Creates a new account group
updateGroup
Edits and updates an account group
deleteGroup
Deletes a single account group
deleteGroups
Deletes multiple account groups in bulk
Tracks updates to asset groups and inventory-related settings.
Endpoint
Description
createAssetGroup
Creates a new asset group
updateAssetGroup
Edits and updates an asset group
deleteAssetGroup
Deletes a single asset group
createManyAssetGroups
Creates multiple asset groups in bulk
updateManyAssetGroups
Edits and updates multiple asset groups in bulk
deleteManyAssetGroups
Deletes multiple asset groups
mergeAssetGroups
Merges two asset groups
createAssetRelations
Creates an asset relation between assets or between an asset and a user
updateAssetCleanUpRules
Edits and updates asset cleanup rules
createAssetStates
Creates new asset states
updateAssetStates
Edits and updates asset states
deleteAssetStates
Deletes asset states
updateIpLocations
Edits and updates IP locations
deleteIpLocations
Deletes IP locations
createIpLocations
Creates new IP locations
deleteAsset
deleteAssets (UI)
Deletes multiple assets in bulk
deleteAssets (API)
Deletes multiple assets in bulk using the API
resolveDedupConflict
Resolves asset duplicates, only keeping a single record in the inventory
createAssetV2
Creates a new asset
updateAssetV2
Updates an asset
createAssetRelationTypes
Creates new asset relation types
updateAssetRelationTypes
Edits and updates asset relation types
deleteAssetRelationTypes
Delete asset relation types
launchAssetOperation
Executes a bulk operation on assets
bulkEditAssets
Edits multiple assets in bulk (deprecated)
bulkDeleteAssets
Deletes multiple assets in bulk (deprecated)
securedBulkEditAssets
Securely edits multiple assets in bulk
securedBulkDeleteAssets
Securely deletes multiple assets in bulk
securedBulkDeleteUsers
Securely deletes multiple users in bulk
launchUserOperation
Executes a bulk operation on users
manageAssetTypes
Creates, edits or deletes asset types
createAssetTypes
Creates multiple asset types in bulk
updateAssetTypes
Edits and updates multiple asset types in bulk
deleteAssetTypes
Deletes multiple asset types in bulk
assetsResync
Forces resynchronization of one or more assets
createAzureCloudScanningTarget
Creates an Azure cloud scanning target
updateAzureCloudScanningTarget
Edits and updates an Azure cloud scanning target
deleteAzureCloudScanningTarget
Deletes a single Azure cloud scanning target
createAdUserPathScanningTarget
Creates an AD user path scanning target
updateAdUserPathScanningTarget
Edits and updates an AD user path scanning target
deleteAdUserPathScanningTarget
Deletes a single AD user path scanning target
createAwsRegionScanningTarget
Creates an AWS region scanning target
updateAwsRegionScanningTarget
Edits and updates an AWS region scanning target
deleteAwsRegionScanningTarget
Deletes a single AWS region scanning target
createIntuneV2ScanningTarget
Creates an Intune scanning target
updateIntuneV2ScanningTarget
Edits and updates an Intune scanning target
deleteIntuneV2ScanningTarget
Deletes a single Intune scanning target
addAsset
Creates a new asset
editAsset
Edits and updates multiple assets in bulk
createRelation
deleteRelation
Deletes an asset relation between assets or between an asset and a user
createCustomField
Creates a custom field
deleteCustomField
Deletes a custom field
Data extraction
Tracks when users export views.
Endpoint
Description
exportView
Exports all data from a selected view, including filters and query
exportFilteredAssets
Exports filtered assets
Discovery configuration
Endpoint
Description
updateScanningTargetByScanningTargetId
Edits and updates a scanning target by ID
updateAllScanningTargets
Edits and updates all available scanning targets
triggerScanNowByScanningTargetId
Triggers a scan for a scanning target by ID
triggerScanNowByFilter
Triggers a scan using a filter
createWindowsComputerScanningTarget
Creates a Windows computer scanning target
updateWindowsComputerScanningTarget
Edits and updates a Windows computer scanning target
deleteWindowsComputerScanningTarget
Deletes a single Windows computer scanning target
createAdComputerPathScanningTarget
Creates an AD computer path scanning target
updateAdComputerPathScanningTarget
Edits and updates an AD computer path scanning target
deleteAdComputerPathScanningTarget
Deletes a single AD computer path scanning target
createIntuneScanningTarget
updateIntuneScanningTarget
deleteIntuneScanningTarget
createChromeOsScanningTarget
Creates a Chrome OS scanning target
updateChromeOsScanningTarget
Edits and updates a Chrome OS scanning target
deleteChromeOsScanningTarget
Deletes a single Chrome OS scanning target
createSccmScanningTarget
Creates an SCCM scanning target
updateSccmScanningTarget
Edits and updates an SCCM scanning target
deleteSccmScanningTarget
Deletes a single SCCM scanning target
createAdDomainScanningTarget
Creates an AD domain scanning target
updateAdDomainScanningTarget
Edits and updates an AD domain scanning target
deleteAdDomainScanningTarget
Deletes a single AD domain scanning target
createIpRangeScanningTarget
Creates an IP range scanning target
updateIpRangeScanningTarget
Edits and updates an IP range scanning target
deleteIpRangeScanningTarget
Deletes a single IP range scanning target
createAirWatchScanningTarget
Creates an AirWatch scanning target
updateAirWatchScanningTarget
Edits and updates an AirWatch scanning target
deleteAirWatchScanningTarget
Deletes a single AirWatch scanning target
createConfigGroup
Creates a config group
updateConfigGroup
Edits and updates a config group
deleteConfigGroup
Deletes a config group
createCredential
Creates a credential
updateCredential
Edits and updates a credential
deleteCredential
Deletes a credential
shareHubCredential
Shares a Hub credential
createAction
Creates an action
updateAction
Edits and updates an action
deleteAction
Deletes an action
scanNowAction
Triggers a scan action
createActionItAgent
Create an IT agent action
updateActionItAgent
Edits and updates an IT agent action
createExclusion
Creates a discovery exclusion
updateExclusion
Edits and updates a discovery exclusion
deleteExclusion
Deletes a discovery exclusion
