Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Hey IT Heroes,
We know how challenging it can be to get a quick, accurate view of your enterprise network. Thatโ€™s why weโ€™re excited to introduce Lansweeperโ€™s FREE IP Scanner! This powerful tool is designed to help you identify and understand everything in and around your network, without breaking the bank.
๐Ÿงก Why You'll Love It:
  2. No Installation Hassles: The tool is a standalone executable with no installation process. Just install Npcap (embedded within the tool) and youโ€™re good to go!
โš™๏ธ Key Features:
Port Scanning:
Risk Identification:
Alerts and Rules:
Iterative Scanning:
โ„น๏ธ Why It's Different:
Unlike other limited free tools or expensive paid options, our free IP Scanner is a standalone example of our commitment to innovation and empowering IT professionals. Itโ€™s our โ€œgiftโ€ to you, and just the beginning of what we have to offer.
๐ŸŽ Get Started:
Download Lansweeperโ€™s FREE IP Scanner today and take the first step towards a more secure, well-understood network. Perfect for IT pros who need a reliable, comprehensive scanning solution without the high cost.
๐Ÿ‘‰ Download Here ๐Ÿ‘ˆ
Feel free to ask any questions or share your experiences with the tool here in our Product Forum. Weโ€™re here to help and would love to hear your feedback!
Happy scanning!
Lansweeper Team
16 Comments
Kiran20
i havw installed this software.
it's nice to see the information of  data and ports, but I'm not able to export data. could someone help  on reports.
Mister_Nobody
Honored Sweeper III
I can't sort each column by click on header...
Mister_Nobody
Honored Sweeper III
I try to scan without creds and lock my AD account.
Also antivirus was in panic.
Kiran20
Also i  notice  UDP  ports details are not shown when we perform full scan range.
VDFilip
Hi Kiran
The port scanner functionality is only doing TCP scans.
The main reason why we decided to not include UDP is because it's very slow, and the results are also not reliable in bulk due to the nature of UDP.
Export functionality can be found in our main product.
Kiran20
Thanks, May i ask if you are referring to Lansweeper classic   product or IP  Scanner tool main  product .
Is it  possible to  have  separate exclusive  ip scanner  product  with  full functionality  reports  having features TCP/UDP  ports scan for  full range.
DonMario73
Nice tool!
I suggest to add credential free scanning capabilities as FING currently does in it's free version.   For some assets the ip scanner was able to recognize the correct model and manufacturer.  For other assets the fields were empty or partially discovered.
KDOUMALIN
Hello, during the execution of the soft, I receveid a Pop-up "This version of the application is no longer supported and will shut down shortly. Please download the latest version from here"
But I did download the latest version of the software.
When I execute the soft, it tries enter this url but it's drop because my VM is not open on internet "ns1-07.azure-dns.com. azuredns-hostmaster.microsoft.com"
 Is It normal ?
VDFilip
Our IP scanner requires internet connection in order to work because it uses an API for device identification.
You are receiving this error message because there is no internet connection present.
Kind regards
KDOUMALIN
Thanks for this return,
But can you tell me what the API points to please ? So I can ask the network team to open on these urls
Aurelijus
Hi there,
By default the option to scan neighbour subnets should not enabled. Did not noticed it before trying my first scan and after it detected some multi-homed device it started to scan other subnets and even made some part of it be blocked as scan was detected.
iescobar
Hello guys, i was going to use the free ip scanner in my class. (cibersecurity) but today its posting it need an upgrade and points you to the download page.  I redownloaded without success.  Does anybody know how to update?
VDFilip
Hi
We released a new version with minimal version increase.
There might be a CDN caching issue wich gives you an older version. (API up to date / exe still cached).
We would recommand to download again the latest version to avoid any caching issues.
itr1
the scanner just opens in the background and closes afterwards - i tested it on different systems with different Antivirus - any hint why this happens?
Thank you!
Jake
This software won't install.  Same results as previous commenter.  Tried on multiple computers.  Would love to try it.
