Showing results forΒ
ShowΒ Β onlyΒ  | Search instead forΒ
Did you mean:Β
Hey IT Heroes,
We know how challenging it can be to get a quick, accurate view of your enterprise network. That’s why we’re excited to introduce Lansweeper’s FREE IP Scanner! This powerful tool is designed to help you identify and understand everything in and around your network, without breaking the bank.
🧑 Why You'll Love It:
  2. No Installation Hassles: The tool is a standalone executable with no installation process. Just install Npcap (embedded within the tool) and you’re good to go!
βš™οΈ Key Features:
Port Scanning:
Risk Identification:
Alerts and Rules:
Iterative Scanning:
ℹ️ Why It's Different:
Unlike other limited free tools or expensive paid options, our free IP Scanner is a standalone example of our commitment to innovation and empowering IT professionals. It’s our β€œgift” to you, and just the beginning of what we have to offer.
🎁 Get Started:
Download Lansweeper’s FREE IP Scanner today and take the first step towards a more secure, well-understood network. Perfect for IT pros who need a reliable, comprehensive scanning solution without the high cost.
πŸ‘‰ Download Here πŸ‘ˆ
Feel free to ask any questions or share your experiences with the tool here in our Product Forum. We’re here to help and would love to hear your feedback!
Happy scanning!
Lansweeper Team
17 Comments
VDFilip
@itr1 @Jake
The app requires internet access to check for updates.
Can you confirm internet is present?
Normally if the version is outdated or no internet connection is present, a pop-up should occur. Have you seen this?
If it's not one of the above, there is probably an issue.
In that case, you might post the error from the log file or eventviewer.
Could you indicate what version of Free IP scanner you are using and on what operating system you are running it?
Kind regards!
JohnHolmes85
Same here, I run it, and you see it in the process, then it just stops. Never actually starts up.
