ssmarr5
How do I get this report to list ALL window asset and not just servers? Great report, just limited to server only. Thanks.
Select Top 1000000 tblADusers.Company,
tblState.Statename,
tblAssets.Username,
tblADusers.Firstname,
tblADusers.Lastname,
tsysAssetTypes.AssetTypename,
tblAssets.SP,
tblAssets.Domain,
tblAssets.Lastseen,
tblAssets.Lasttried,
tblAssets.IPAddress,
tsysIPLocations.IPLocation,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.Serialnumber,
tblADComputers.AssetID,
tblAssetCustom.PurchaseDate,
tblAssetCustom.Warrantydate,
tblOperatingsystem.InstallDate,
tblOperatingsystem.PlusProductID,
SubQuery.Name As Relation,
SubQuery.Username As RelatedUser,
SubQuery.Userdomain As RelatedUserdomain,
SubQuery.Comments As RelationComments,
SubQuery.StartDate As RelationStartdate
From tblAssets
Inner Join tblSystemEnclosure On
tblAssets.AssetID = tblSystemEnclosure.AssetID
Inner Join TsysChassisTypes On tblSystemEnclosure.ChassisTypes =
TsysChassisTypes.Chassistype
Inner Join tsysIPLocations On
tblAssets.IPNumeric Between tsysIPLocations.StartIP And
tsysIPLocations.EndIP
Inner Join tblADComputers On tblAssets.AssetID = tblADComputers.AssetID
Inner Join tblADusers On tblADusers.Username = tblAssets.Username And
tblADusers.Userdomain = tblAssets.Userdomain
Inner Join tblOperatingsystem On
tblAssets.AssetID = tblOperatingsystem.AssetID
Left Join (Select Top 1000000 tblAssetUserRelations.AssetID,
tsysAssetRelationTypes.Name,
tblAssetUserRelations.Username,
tblAssetUserRelations.Userdomain,
tblAssetUserRelations.Comments,
tblAssetUserRelations.StartDate
From tblAssetUserRelations
Inner Join tsysAssetRelationTypes On
tsysAssetRelationTypes.RelationTypeID = tblAssetUserRelations.Type
Where tsysAssetRelationTypes.Name = 'owned by') SubQuery On
SubQuery.AssetID = tblAssets.AssetID
Order By tblADusers.Company,
tblState.Statename,
ssmarr5
Thanks, that was the ticket, I 'Left Join' all the 'Inner Joins' and got all the information I needed. Much appreciated.
RCorbeil
Honored Sweeper II
Since you don't have a WHERE clause filtering anything out, more than likely one of the inner joins is filtering out your non-servers.
Do you have an IP range defined for your non-servers? (Configuration > Asset Groups > IP Address Range locations) That's the first obvious possibility that leaps out at me. The rest of the tables you're linking to should all be suitably populated, so shouldn't cause non-servers to be filtered out. If you want to test to be sure, change the INNER JOIN tsysIPLocations to a LEFT JOIN. If that's the ticket, you should see your non-servers show up with no value in the IPLocation column.
Reports & Analytics
